Simulating ISO 527 Tensile Test
    • Kurrnin
      Hi everyone,
      How would I go about simulating the ISO 527 standard for tensile testing? It states that the part is stretched at 5 or 50mm/min until failure. How would I simulate that in static structural?
      Ignore the time. Just solve in Static Structural using 1 step that ends at 1 second and use whatever an appropriate displacement is required to take the model past the failure displacement.
    • Kurrnin
      I’m sorry I’m not sure I follow? What do you mean by an appropriate displacement?
      What is the material you are testing?  What is the Elongation at Break?
      If Elongation at break is 0.1% then the displacement is 0.001*length.
      If Elongation at break is 50% then the displacement is 0.5*length.
    • Kurrnin
      Okay I think I understand now, thank you very much for the help!
      The material I'll be using is PLA
Viewing 4 reply threads
  • The topic ‘Simulating ISO 527 Tensile Test’ is closed to new replies.
