September 18, 2025 at 12:37 am
September 19, 2025 at 8:14 pm
GLUO
Ansys EmployeeHi
WIRELOSS provides solid loss on the solid windings. If the winding is stranded, WIRELOSS in Simplorer should be 0. The behavior in your screenshot is not expected. Could you let me know what version are you using?
GL
September 22, 2025 at 2:35 am
2280551760
SubscriberHi
1、The winding is stranded. The version I am using is 2024R2. The motor is connected in a delta configuration. Is the simulation result related to the connection method?
2、Using the simplorer-maxwell method,Why is standardloss not equal to 3*I^2*R?
Thanks
September 24, 2025 at 3:22 pm
GLUO
Ansys EmployeeHi,
- No. I cannot reproduce this weird wireloss in 24R2 version. Is the simplorer model converged?
- StrandedLoss is dependent on the object’s material conductivity. It represents the loss due to the DC resistance only and uses the cross-sectional area of the object that is assigned with the excitation. It is calculated by 1/sigma*Integration of J^2 over cross section.
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- Two way coupling for Maxwell and thermal problem
- simplorer-maxwell
1530
1386
1210
