TAGGED: ansys-spaceclaim, facets, Simplify, spaceclaim
March 26, 2024 at 10:48 am
JHL
SubscriberHi all,
I want to add an obstruction to an artery as in this video from the ansys course, attached also an image of that geometry(https://www.youtube.com/watch?time_continue=11&v=zB_Se_SB0E0&embeds_referring_euri=https%3A%2F%2Fcourses.ansys.com%2F&source_ve_path=Mjg2NjY&feature=emb_logo). Attached you can find my geometry, it is a faceted solid. I want to simplify the geometry so that adding the obstruction works, simply deleting faces(to add the obstruction there) does not seem to work and gives me an error. Can anyone help? -
March 26, 2024 at 11:14 am
Devendra Badgujar
Forum ModeratorHello,Â
What error do you get while performaing that operation?Â
Devendra
March 26, 2024 at 11:47 am
JHL
SubscriberIt says: 'failed to remove faces'
March 27, 2024 at 9:15 am
Devendra Badgujar
Here is the quick summary of Adding Obstructions to the Original Artery Geometry | Ansys. Can you please let me know at which step are facing this issue as per the steps mentioned in the above course?Â
Instead of merge tool, you can use Fill tool to merge those faces and see if that helps.Â
DevendraÂ
April 4, 2024 at 12:36 pm
JHL
Subscriberthanks so much, that worked!
April 4, 2024 at 12:43 pm
Devendra Badgujar
Forum ModeratorGreat, thanks for the update.Â
DevendraÂ
- The topic ‘simplify faceted solid for adding obstruction’ is closed to new replies.
5939
1307
