May 6, 2026 at 4:05 am
Amrith Mariappan
SubscriberHi everyone,I am encountering a Signal 11 (Segmentation Violation) during MPP initialization that occurs only with my custom-built LS-DYNA R16.2 executable, while the standard Ansys-distributed binary runs the identical keyword file to normal termination without any errors.Environment & Executables- Custom build:mppdyna.execompiled from the R16.2 source makefile (Intel Fortran 19.0 + Intel MPI 2019.6.166, double precision I8R8, WINX64). I did not modify any source files or build flags — I simply ran the default makefile to verify that the custom library would execute without errors.- Standard binary:lsdyna_mpp_sp_msmpi.exe(Ansys-distributed) — same keyword file, same machine, same MPI run command completes successfully with normal termination.- Version: LS-DYNA R16.2-151-g276cb33db2Problem SummaryWhen I run the custommppdyna.exewith thermal properties included, the solver crashes immediately after initialization:initialization completed>>>>> Process 0 <<<<<>>>>> Signal 11 : Segmentation Violation <<<<<The crash happens at Problem cycle = 0, right after MPP decomposition and initialization finish. No d3plot or binout data is written beyond the initial state.Critical Observation: Thermal Dependency- With thermal cards active: The custom MPP executable segfaults every time (tested with-n 1and-n 2).- Without thermal cards: The custom MPP executable runs perfectly fine to normal termination.- With thermal cards + standard Ansys binary: Runs perfectly fine to normal termination.This strongly suggests the issue is tied to how the custom-built executable handles thermal initialization in an MPP + S-ALE environment, rather than a keyword syntax error.Keyword Cards Used in the ModelThe simulation is a 2D axisymmetric S-ALE hypervelocity impact problem using the following cards:-*KEYWORD,*TITLE-*MAT_ELASTIC_PLASTIC_HYDRO_TITLE(HSLA 100 Steel, Tungsten Carbide)-*MAT_ALE_VACUUM_TITLE-*MAT_THERMAL_ISOTROPIC_PHASE_CHANGE_TITLE(Steel)-*MAT_THERMAL_ISOTROPIC_TITLE(Tungsten Carbide, Vacuum)-*EOS_GRUNEISEN_TITLE-*NODE-*ALE_STRUCTURED_MESH,*ALE_STRUCTURED_MESH_CONTROL_POINTS-*ALE_MULTI-MATERIAL_GROUP-*ALE_STRUCTURED_MESH_VOLUME_FILLING(ALL, BOXCOR, ELLIPSOID)-*PART,*SECTION_ALE2D_TITLE-*INITIAL_TEMPERATURE_SET-*DEFINE_BOX_TITLE,*DEFINE_VECTOR_TITLE-*BOUNDARY_SALE_MESH_FACE(SYM, NONREFL)-*SET_PART_LIST_TITLE-*CONTROL_ALE,*CONTROL_BULK_VISCOSITY,*CONTROL_ENERGY,*CONTROL_HOURGLASS-*CONTROL_MPP_DECOMPOSITION_DISTRIBUTE_ALE_ELEMENTS-*CONTROL_SOLUTION,*CONTROL_TERMINATION-*CONTROL_THERMAL_NONLINEAR,*CONTROL_THERMAL_SOLVER,*CONTROL_THERMAL_TIMESTEP-*CONTROL_TIMESTEP,*CONTROL_UNITS-*DATABASE_family (D3PLOT,D3THDT,GLSTAT,MATSUM,NODOUT,TPRINT, etc.)-*DATABASE_EXTENT_BINARY-*ENDRun Command (Custom — Fails)bashmpiexec -n 2 "...\mppdyna.exe" i="sale_shot10_umat44v_T09-fine.k" memory=200mRun Command (Standard — Succeeds)bashmpiexec -n 2 "...\lsdyna_mpp_sp_msmpi.exe" i="sale_shot10_umat44v_T09-fine.k" memory=200mQuestionSince the standard Ansys MPP binary handles the identical thermal + S-ALE setup without issue, but the default, unmodified custom build crashes during thermal initialization, what could be causing this? Is there a known compiler/MPI flag, preprocessor directive, or library linkage issue in the R16.2 makefile that affects thermal solver initialization in MPP mode? Any guidance on resolving this would be greatly appreciated.Thanks,Amrith
Viewing 0 reply threads
