January 5, 2023 at 9:17 am
Mustapha EL MLILES
SubscriberHello everyone,
I want to model a shock wave for exp with an overpressure of 10kPa and a positive phase duration of 0.3s, is there a way to model this shock wave directly (injecting a function of the shock wave), or the only way is by finding the equivalent TNT mass?
Thank you!
January 5, 2023 at 6:10 pm
Reno Genest
Ansys EmployeeHello Mustapha,
What do you mean by shockwave? Are you modeling a blast from some sort of explosive? If so, one way to model a blast load (pressure) on a structure without explicitly modeling the explosive and the air is to use the keyword *LOAD_BLAST_ENHANCED to apply a pressure load directly on the structure. You will have to define the equivalent mass of TNT with the “M” parameter for this keyword. You will find more information here:
https://ftp.lstc.com/anonymous/outgoing/support/PRESENTATIONS/blast_slavik_ucsd.pdf
https://www.dynalook.com/conferences/european-conf-2009/J-I-03.pdf/view
You will find more papers by searching on dynalook.com
If you know the pressure vs time profile for each element of the structure or if you can assume a constant pressure vs time profile for a group of elements, you can apply the blast load pressure using one of the following keywords:
*LOAD_SEGMENT
*LOAD_SEGMENT_SET
You can define the pressure vs time profile using LCID and *DEFINE_CURVE. See the LS-DYNA user manual vol I for more information:
https://lsdyna.ansys.com/manuals/
Let me know how it goes.
Reno.
January 5, 2023 at 9:39 pm
Mustapha EL MLILES
SubscriberHello Reno,
Thank you I really appreciate your response. In fact, I want to model a shock wave caused by an explosion with the following parameters (overpressure of 10kPa and a positive phase duration of 0.3s) and visualize its impact on a structure.
I have already done the mass calculation of the equivalent TNT, and I found that the shock wave corresponds to a TNT of 170 tonnes situated at a distance of 660 meters from the structure. I want to know if I can use these values with the *LOAD_BLAST_ENHANCED, if yes, where can I find this keyword on LS Dyna workbench, please.Regarding the second way, I don't think it will work, since this method doesn't reflect the physics of the shock wave like the reflected wave...Thank you again. -
January 5, 2023 at 10:07 pm
Reno Genest
You can check the validity of *LOAD_BLAST_ENHANCED using the following formula:
See the LS-DYNA user manual vol I for more details.
To use *LOAD_BLAST_ENHANCED in WB LS-DYNA, you can create a command snippet:
To specify the faces of the structure where the blast load will be applied, you can create a named selection with an ID:
Let me know if this helps or not.
Reno.
February 8, 2024 at 7:13 am
Swanand Kelkar
SubscriberHello Mustapha,
we are also working on same problem, can you share the reference calculations for the calculation of TNT mass and charge distance ?
It will be very helpful to me. I was stucked here from last 1 month.
Thanks and Regards,
Swanand Kelkar
January 5, 2023 at 10:11 pm
Reno Genest
Ansys EmployeeNote that you can use LS-PrePost to create the *LOAD_BLAST_ENHANCED keywords to ensure you have the correct format. You can download LSPP here:
https://ftp.lstc.com/anonymous/outgoing/lsprepost/4.9/
Then, you can save the .k file using LSPP and open the .k file with a text editor to retrieve the keyword.
Reno.
January 6, 2023 at 10:40 am
Mustapha EL MLILES
Thank you a lot, I followed your instructions (creating keywords on LSPP and copying them to LS workbench) and it worked perfectly.
Thank you again.
January 6, 2023 at 5:50 pm
Reno Genest
Sounds good. I'm glad it worked well for you.
Have a good day!
Reno.
- The topic ‘Shock wave ansys LS Dyna’ is closed to new replies.
