April 26, 2020 at 3:30 pm
Kevin1993
SubscriberDear colleagues
I need help to solving my shell element model, my model experiencing error and several warning. One of the warning is convergence problem.
To solve this problem i try to refine the mesh, unfortunately even with 5 mm mesh size didn't solve the problem.
Is there anything wrong with my model setup?
Does solver type can affect this ? because right now i'm using "direct" solver, not iterative.
My model is attached in this post.
Your help will be much appreciated.
Thank youÂ
April 26, 2020 at 6:03 pm
peteroznewman
SubscriberAre you using the free Student license that has node limits or the unlimited Research license?
April 26, 2020 at 6:07 pm
Kevin1993
SubscriberI'm using unlimited research license.
April 26, 2020 at 6:30 pm
peteroznewman
SubscriberMesh everything with an element size of 25 mm. Smaller elements with a plasticity material model make it harder to converge.
You can use a single step analysis with 30 mm of displacement.
Use Initial and Minimum Substeps of 30 and it will solve to the end.
April 26, 2020 at 6:35 pm
Kevin1993
SubscriberThanks Peter, i will try and inform you the result. -
April 27, 2020 at 1:18 am
Kevin1993
Subscriberit worked, thanks Peter.
- The topic ‘shell element nonlinear model error’ is closed to new replies.
5874
1306
