3D Design
3D Design
Sheet Metal Bug
    • Enrico Cabassi
      We noticed that in this post the same problem that has been reported for a long time has been reported, when will you solve it? We are not the only ones who often get the pieces wrong because of your problem that doesn't seem to interest you, can you solve it? The drawing table must give correct and not incorrect information!
      Regards
      /forum/forums/topic/sheet-metal-bug-4/?template=discovery
    • Devendra Badgujar
      Hello Francesco,
      The issue has been notified to the development team and same has been duly noted. We will let you know as we hear more on the same.
      Thanks,
      Devendra
    • Enrico Cabassi
      Hello Devendra
      Sorry, but you've been giving me the same answer to me and other companies for 3 years, I don't think it's that complicated to solve the problem.
      Because if the development is not put in the drawing format it is correct, while if it is put in the drawing format it is wrong!.
      You must make sure to position the developed sheet metal in the same way also in the drawing
      Regards
    • Devendra Badgujar
      Hello Francesco,
      I understand, development is aware of this and are looking into it.
      Devendra
  • The topic ‘Sheet Metal Bug’ is closed to new replies.
