3D Design
3D Design
Shared Topology by “Form new part”
    • cs437
      I created 2 fluids in different domains; however, the node was not aligned properly. Could I use "form new part"? to do conformal mesh? Does it have an impact on the interface?
    • Aniket Chavan
      If you are using DesignModeler, yes you'll need to form a new part. If you are using SpaceClaim, you can share interfaces by going to the Workbench tab, using share tool.
      -Aniket
    • Keyur Kanade
      Check following links
      https://www.youtube.com/watch?v=4JhDn0V26l0
      https://www.youtube.com/watch?v=h43E1YO1LiM
    • Keyur Kanade
      If this helps, please mark this post as 'Is Solution' to help others.
    • cs437
      Thank you and I understand this; however, the conformal mesh could not do at the interface of liquid-gas, right? Because the interface boundary will not be shown then. Also, the conformal mesh is ok only MRF approach, right? What about sliding mesh?
      Sliding would be non-conformal: have a look in the Fluent tutorials accessible via help.
      Gas-liquid contact would be covered via multiphase models unless there's a wall in the way, in that case that would usually be conformal.
Viewing 5 reply threads
  • The topic ‘Shared Topology by “Form new part”’ is closed to new replies.
