February 23, 2024 at 4:41 pm
Tom Perkin
SubscriberI am a student looking to investigate Shape Memory Alloy Actuators.
On ANSYS I am wanting to model the expansion of a SMA wire with increasing Heat. I have been trying to use SS-Thermal and S-Structural for this. The main issue I am finding is defining the material. I created a new material, added in the Shape Memory effect, Thermal Expansion Coe and Isotropic thermal conductivity. Yet when I run the simulation I am getting results of maximum deformation of 9e-5M when I am expecting roughly 4mm.
There is more data I have for the material but I do not know how to add these to the material if I can get some advice. I have attached the properties I am hoping to use.
I am new to using ANSYS so still learning the basics. Thank you for your help.
February 26, 2024 at 2:26 pm
David Mercier
Ansys EmployeeÂ
Hi, I think you should have a look into this paper maybe: http://dx.doi.org/10.1177/1045389X11401450
To implement such material behaviour, you might have to create a usermat using MAPDL capabilities:
- The topic ‘Shape Memory Alloy’ is closed to new replies.
6750
1325
1087
