April 9, 2024 at 10:51 am
Jan-Patrice SIMONEAU
SubscriberHello, I am trying to follow the approach 1 of the document entitled "Setting Up the Periodic Pressure Drop as an Output Parameter". The first window is Ok :
but Fluent does not create automatically the report definition, as it should do according to the document :Â
It is therefore not possible to follow the proess.
Thanks for your help.
April 9, 2024 at 11:13 am
Forum ModeratorWhich document is that?
April 9, 2024 at 11:20 am
SubscriberThis is this document : https://support.ansys.com/knowledgeresources/getfile?fn=2067016_Periodic_pressure_drop_as_output_parameter_2021.pdf&fp=%2Fsolutions%2Fattach%2F2067016_Periodic_pressure_drop_as_output_parameter_2021.pdf
April 9, 2024 at 12:56 pm
Forum ModeratorDid you use a periodic pair defined from the mesh or the non-conformal approach?Â
April 9, 2024 at 2:05 pm
Forum ModeratorAnd have you run the model & displayed the "periodic static pressure" on the boundary?
April 10, 2024 at 6:16 am
SubscriberWe use a non-conformal approach, ran the model and dispayed the periodic static pressure.
April 10, 2024 at 8:58 am
Forum ModeratorI wonder if the report is linked to the conformal option. On older cases the periodic was a single boundary so getting a "pressure" on both ends wasn't possible whereas the nonconformal option has an interface at each end.Â
It worked on a test case here, but the report only triggered after running the model. Good spot, and it'll give the solution author something to do for a day or two! :)Â Â
April 11, 2024 at 6:41 am
Subscriberok thanks,Â
- The topic ‘Setting Up the Periodic Pressure Drop as an Output Parameter’ is closed to new replies.
5964
1307
