January 9, 2024 at 1:23 am
2022100400
SubscriberMay I ask why, when simulating metamaterial surfaces, the substrate is not entirely placed within the simulation region, as shown in the second image below? Although it doesn't affect the phase, it does have an impact on the transmittance. Why is the option of placing the entire substrate inside not considered?
January 10, 2024 at 2:58 pm
Niki Papachristou
Forum ModeratorHi Ceshi,
Thank you for reaching out to us! I believe that the reason is to reduce the time and storage consumption. Since in the metameterial surfaces simulation we focus on the phase results and these are not affected from the simulation region, then going for your first case should be enough.
Kind Regards,
Niki
- The topic ‘set up the simulation region’ is closed to new replies.
1530
1386
1209
