Set number of cores in System Couping standalone.
    • Lukas
      I am running 2way FSI Fluent-Mechanical in SC standalone. Although I set number of cores in Fluent and Mechanical prior exporting. FSI is running on single core for each participant. I went through documentation, but it rather confuses than helps. I run FSI on local machine with 16 cores and would like to use 6 cores for Fluent and 6 cores for Mechanical. Does anyone has idea where to set it?
      Btw. as Mechanical and Fluent never run in parallel I could set even 12 cores for each, couldn´t I?
      Thanks
    • Federico
      Hello Lukas,
      you can set up the Parallel Partitioning as follows:
      Under Participant Weights, specify the resource weighting for each coupling participant as a real number.
