SET Ambient Pressure and Temperature
    • mlutfiaziz32
      hai guys, ca you tell me how to set ambient pressure and ambient temperature in domain if i use fluent? thanks
    • Keyur Kanade
      please check
      /forum/forums/topic/gauge-pressure-vs-operating-pressure/
      /forum/forums/topic/operating-pressure-3/
      please search, this community will have more posts on this topic.
      Keyur
      If this helps, please mark this post as 'Is Solution' to help others.
    • mlutfiaziz32
      ok sir, thanks for your help.
    • Karthik Remella
      Administrator
      If the answer helped you, could you please mark this as 'Is Solution' so it helps the community?
      Thank you.
      Best Regards,
      Karthik
    • mlutfiaziz32
      oke sir, but there are some problems. if i set material air is gas ideal. why i dont set operating condition pressure and spesific density?
    • DrAmine
      you can set both even with ideal gas. For low mach numbers flows even very important to set operating pressure. For buoyancy related cases setting an operating density is also important to provide correct input on pressure boundaries
    • mlutfiaziz32
      in notification if  i use ideal gas so density specific recommended velue Zero.
    • DrAmine
      Ignore that notification. I recommend providing an operating density. I usually use zero but in certain cases and to facilitate setting up multicomponent cases and if the conditions outside are the same I usually provide the density of the outside as operating density.
    • mlutfiaziz32
      sorry mr. abenhadj, do i must set pressure location???
    • mlutfiaziz32
      in operating conditions
    • Karthik Remella
      Administrator
      You can leave the pressure location as default. That is alright.
      As suggested by my colleague, please do set the operating density if you are working with buoyancy related flows. You could use the default value of the operating pressure in most flows.
      Thanks.
      Best,
      Karthik
Viewing 10 reply threads
  • The topic ‘SET Ambient Pressure and Temperature’ is closed to new replies.
