Session File in Post Processing
    • Mohamed Abu-bakr
      I am performing steady simulation on a pipe, and I would like to generate a session file to create 100 planes along flow normal to the pipe. Some suggested to use a loop in session file in CFD post, but I don't know how to write a code for a loop to change plane location and name.
      Thanks
    • seeta gunti
      Open CFD-Post and choose
      Session/New Session/test.cse
      Session/Start Recording
      File/Load Results Test_001.res
      Insert/Location/Point 1,1,1
      Insert/Location/Plane Z=0
      File/Export Locations Plane 1,Point1 Select Variable Pressure
      Session Stop Recording
      This produces an export file called export.csv and a session file called test.cse
      The session file can be replayed by opening the CFX Launcher, choosing tools/command line and in the resulting command line running the command
      play test.cse
      Now edit the session file to place a for loop around the plane creation. Use the ! operator to indicate the line should be interpreted as Perl. See "Power Syntax" in the CFX documentation for more details. A quick google search will get you the syntax for common tasks (for loops, if statements etc).
  • The topic ‘Session File in Post Processing’ is closed to new replies.
