June 4, 2026 at 5:48 pm
Dennis Chen
SubscriberHello, I am getting an error as shown below when trying to use sensor_define_element_set.  in the below parameter, if I set comp = PRIN1, below error shows up.  if I set it to XX, YY, ZZ, it doesn't
I have database_elout, database_history_solid and control_output all properly set.  If anyone can think of anything causing this, I would realy appreciate it. Â
June 5, 2026 at 8:55 am
ErKo
Ansys EmployeeÂ
Hi Dennis
Suppose you use 25R2 so that uses LS-Dyna R14 it does not work since PRIN1 option was not there yet.
It is there and available in R16 which comes with 2026R1 luckily – I tried it and it works.Â
All the best
Erko
June 5, 2026 at 1:21 pm
Dennis Chen
SubscriberHi Erko, Thank you! I am stuck on 2025R2 (R14?) at work unfortunately but it's good to know the limitation.Â
ThanksÂ
1343
