August 15, 2017 at 2:52 am
sgvs
SubscriberI want to model mixing of two gases or a gas and a liquid. There are no reactions. Which model should I choose - Species transport or Multiphase Flow model? Kindly guide me on choosing model
November 3, 2017 at 1:10 am
raul.raghav
SubscriberThe two-phase gas-liquid or liquid-liquid flow forms a free surface (the interface). So a VOF model can be used for such cases to track the interface between the fluids. Gas-gas flow on the other hand would not form a free surface as it mixes in the molecular level. Depending on which solver you are using, it would easier to direct you to the model that would be most appropriate. More information about the physics of the flow is also required for accurate modeling - interfacial drag, volume fraction of the phases etc. The following documents might be help for you.
Fluent: https://www.sharcnet.ca/Software/Fluent14/help/flu_th/flu_th_chp_multiphase.html
CFX: https://www.sharcnet.ca/Software/Fluent14/help/cfx_mod/i1384390.html
- The topic ‘Selecting model for two phase flow’ is closed to new replies.
3492
1057
1051
965
942
