November 1, 2023 at 2:58 pm
November 1, 2023 at 5:06 pmAmrita PatiAnsys Employee
I believe you will have to rotate the structure and shift it.
Amrita -
November 1, 2023 at 5:19 pmAlbi.PaniSubscriber
Ok, so there is no way to rotate the object as I need? It should be a nice thing to implement
November 1, 2023 at 5:35 pmAmrita PatiAnsys Employee
I believe it is quite straightforward to rotate and shift. But if you think there are some complicated cases when it would make it much simpler to have this feature, you can submit a feature request on ix: Ideas Exchange.
Amrita
- The topic ‘Select a new axis of rotation?’ is closed to new replies.
Ansys Innovation Space
- Difference between answers in version 2024 and 2017 lumerical mode solution
- Errors Running Ring Modulator Example on Cluster
- INTERCONNECT – No results unless rerun simulation until it gives any
- Import material .txt file with script
- Help for qINTERCONNECT
- Trapezoidal ring
- Issues with getting result from interconnent analysis script
- Topology Optimization Error
- Edge Coupler EME Example Issue
- How to measure transmission coefficients on a given plane .
543
523
225
209
