TAGGED: #fluent-#ansys, ansys-cfd, error, mechanical, mechanical-workbench, mesh, student-version
November 30, 2024 at 6:44 am
21103072
SubscriberI am a student version user-2024 R2 and I have been getting this 'Type Mismatch error' for 2 days the source seems to be 'Javascript runtime error'. I imported a geometry from Solidworks in STEP file format into Design modeler, then I create a uniform Enclosure of 10 meters. After that I create a Boolean and subtract the Tool body (The Geometry) while preserving it and then choose the domain (The Enclosure) as the Target body. Everything is perfect till this part. Then I open ANSYS mechanical to mesh the Geometry and get this error. I referred to your [revious post online and tried this in Command prompt as administrator
regsvr32.exe ole32.dll
regsvr32.exe atl.dll
regsvr32.exe oleaut32.dll
regsvr32.exe scrrun.dll
regsvr32.exe jscript.dll
regsvr32.exe vbscript.dll
move "%appdata%\ansys" "%appdata%\ansys.old"
It all registered itelf successfully all the commands were executed, I restarted the system and re opened ANSYS again and I encountered the same error again what do I do next? I already deleted and reinstalled ANSYS to give a clean slate and re-did everything once again. What do I do next? -
December 3, 2024 at 5:41 am
Ashish Khemka
Forum ModeratorHello,Â
I think you must have seen the response here : Script Error 800a000d in meshing
Ashish Khemka
January 9, 2025 at 3:56 pm
dimme32
SubscriberHas anyone managed to solve this issue? I'm experiencing the same problem in Fluent, but only when I use the "preserve tool bodies" function in Design Modeler. Can anyone help me fix it?
January 11, 2025 at 7:36 am
Ashish Khemka
Can you please create a new thread for the query? I will close this topic.
Ashish Khemka
- The topic ‘Script error Code: 800a000d’ is closed to new replies.
4612
1515
1386
1209
