February 2, 2021 at 4:29 pm
Jirong
SubscriberHi All,nI'm trying to run a FSI problem on HPC via slurm script. The two participants (ansys mechanical + FLUENT) seems not being coupled together, *scl file stopped updating after the Setup Validation. Although the two participants were generating some results, the results were solved separately and not coupled. n I know that ANSYS does not officially support slurm. But I see many people shared their successful experiences, and our school only uses slurm. So I would like to see if anyone has suggestions about this. I would appreciated it very much.Thanks,nJirongn -
February 11, 2021 at 4:07 pm
Stephen Orlando
Ansys Employee.Hi Jirong,
When submitting a System Coupling job to a job scheduler (System Coupling supports Slurm), you'll need to add the command PartitionParticipants to the .py launch script. The details are discussed more here: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/sysc_ug/sysc_userinterfaces_advtasks_parallel.html
Please see this tutorial for how to set up the .py launch script. I recommend using the method in this tutorial with .scp files instead of the .scl file method.
.If you post your .py script and Slurm script I might be able to provide more suggestions.
February 11, 2021 at 8:15 pm
Jirong
SubscriberHi Steve,
Thanks for your information! And I'm glad that system coupling supports Slurm, that's a great news for me. But I am using ANSYS via our the high performance computer in my university. I don't have an account to open the links you shared. Is there any other way to look those links?
BTW, under my FSI file directory, I created those files with the guidance from System Coupling Users' Guide (Workflows for system coupling using the Command Line). I have *.dat file for ANSYS Mechanical,*.cas and *.jou (journal file) for FLUENT, and *.sci file for system coupling. I didn't notice any python script needed, so I don't have a .py script. But I have my slurm script pasted here. Here is my slurm script. Any suggestions would be nice.
#!/bin/bashÂ
#SBATCH --job-name   ANSYS_FSI
#SBATCH --time     02:00:00     # Walltime
#SBATCH --ntasks    3
#SBATCH --mem-per-cpu  16gb        # Memory per CPU
#SBATCH -o s2.out        # stdout
#SBATCH -e s2.err        # stderr
#SBATCH --hint     nomultithread   # No hyperthreading
cd /panfs/roc/groups/14/tranquil/li000096/ansys/dhp/Slurm/New_large
module load ansys/20.1
COMP_CPUS=$((SLURM_NTASKS-1))
MECHANICAL_CPUS=1
FLUID_CPUS=$((COMP_CPUS-MECHANICAL_CPUS))
export SLURM_EXCLUSIVE="" # don't share CPUs
echo "CPUs: Coupler:1 Struct:$MECHANICAL_CPUS Fluid:$FLUID_CPUS"
echo "STARTING SYSTEM COUPLER"
ANSYSDIR=/panfs/roc/msisoft/ansys/20.1/v201
SERVERFILE=scServer.scs
srun -N1 -n1 /bin/hostname | sort > my_node_list
$ANSYSDIR/aisol/.workbench -cmd ansys.services.systemcoupling.exe -inputFile coupler.sci &
# Wait till $SERVERFILE is created
while [[ ! -f "$SERVERFILE" ]] ; do
  sleep 1 # waiting for SC to start
done
sleep 1
# Parse the data in $SERVERFILE
cat $SERVERFILE
read hostport
read count
read ansys_sol
read tmp1
read fluent_sol
read tmp2
set `echo $hostport | sed 's/@/ /'`
echo $1 > out.port
echo $2 > out.host
echo $ansys_sol > out.ansys
echo $fluent_sol > out.fluent
) < $SERVERFILE
read host < out.host
read port < out.port
read ansys_sol < out.ansys
read fluent_sol < out.fluent
echo "Port number: $port"
echo "Host name: $host"
echo "Fluent name: $fluent_sol"
echo "Mechanical name: $ansys_sol"
echo "STARTING FLUENT"
fluent 3ddp -g -t$FLUID_CPUS -ssh -mpi=intel -scport=$port -schost=$host -scname="$fluent_sol" -cnf=my_node_list -i fluidFlow.jou > fluent.out || scancel $SLURM_JOBID &
sleep 2
echo "STARTING ANSYS"
# Run Ansys
ansys201 -b -mpi ibmmpi -np $MECHANICAL_CPUS -scport $port -schost $host -scname "$ansys_sol" -cnf=my_node_list -i structural.dat > struct.out || scancel $SLURM_JOBID &
Thanks,
Jirong
February 16, 2021 at 4:46 pm
Stephen Orlando
Ansys EmployeeTo get the links to work, launch the Ansys Help from Fluent (or any other Ansys software). This will open the help in a browser. Copy the link I sent into the same browser session.
Please do this tutorial, and you'll see how to set up the python script. When System Coupling is launched from the slurm script, System Coupling will automatically launch Fluent and Mechanical. So manually launching Fluent and Mechanical from the slurm script isn't the correct process.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/sysc_tut/sysc_tut_oscplate_cli_fluent.html
June 2, 2021 at 8:40 pm
Azdine
Subscriber.Hi Jirong,
Did you manage to solve your issue? I have bumped into the same problem. Could you help me work it out?
Thank you
- The topic ‘*.scl file is not updated, participants are not coupled when running FSI on HPC’ is closed to new replies.
3597
1283
1117
1068
983
