Scaling Problem with Inlet Flow
    • Chris Roberts
      Hello all,
      I have a question relating to scaling up an inlet boundary condition. I have two models I am trying to simulate with different inlet areas which I will explain in detail to clarify my question.
      My first model has an inlet area of 602 mm^2 with a inlet velocity of 0.00000968992248 m/s.
      My second model has an inlet area of 402 mm^2. My goal is to scale up model 2's inlet to the the same inlet velocity as the 602 mm^2 inlet. Basically with my second model due to CAD restrictions my inlet size is stuck at 402 mm^2. I cannot increase it to match model 1. So since I cannot scale the dimensional size I would like input a velocity that would give me the same velocity/area as model 1 so they are equal. Is this possible in ansys with a simple ratio formula ? Is there a way to calculate this new velocity so they both match and account for the scale up ?
      Thank you all for the help!
    • SRP
      Reynolds number can remain constant in both scenarios. After that, try to determine the velocity for the second scenario.
      Thank you
    • Chris Roberts
      Hello SRP,
      I checked the velocity being produced for the second model and it is different so I am not sure how to assign the correct velocity value to match the output correct if you can clarify that part from your reply. Thank you
      Are you trying to match mass flow? Or velocity?
    • Chris Roberts
      Hello Rob,
      I can match either one it does not matter on my end. The mass flow rate into the 602 mm^2 inlet area is 0.00000581 kg/s. If there is a way to scale it and match this same flow for the 402 mm^2 thats fine. Either mass flow or velocity both would be fine as long as I can scale it correct so both surface areas are producing the same inlet flow into the domain. Thank you for your reply Rob!
      Then why don't you scale by area? It's a relatively simple calculation on paper. If you're not sure, ask your Prof.
Viewing 5 reply threads
  • The topic ‘Scaling Problem with Inlet Flow’ is closed to new replies.
