Electronics
Electronics
Sawtooth voltage graph.
    • andrein13
      When I simulate the secondary voltage of a transformer I get a sawtooth voltage graph. I specify that I use the formula U * sin (2 * pi * 50 * time).How can I get a graph with a sine waveform?nThank you!n
    • icellb1
      Hi, ,nCould you check if your time step in solution setup is too large? Try making it 1/20 of the period. n
    • andrein13
      Hi,nI set stop 0.1 s and step size 0.005.nn
    • icellb1
      Hi, nThis windows is under Save fields tab so it's not for defining calculation step size. Please go to general tab and define step size.n
  • The topic ‘Sawtooth voltage graph.’ is closed to new replies.
