August 11, 2021 at 5:34 pmmichele.thompsonSubscriber
Hello - Should the 30-day free trial allow you to do a Save As? I am able to save a file without error, but the files are empty, is this expected behavior with the free trial?Â
August 12, 2021 at 6:31 amSubashni RavichandranForum Moderator
Hello Michele Thompson
The files should be allowed to save. Although let me check with team here.
This could be some other issue. Are you saving the file as .dsco or in any other format?
Does this issue occur with the sample files as well?
September 3, 2021 at 9:24 amSubashni RavichandranForum Moderator
Any update on this? Have you tried saving the sample file?
- The topic ‘Save As with 30-day free trial’ is closed to new replies.
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Warning Plugin Error Geometry in Design Modeler
- SpaceClaim stops sharing topology
599
591
565
366
