August 25, 2020 at 8:56 pm
roshanpj4
SubscriberHi all,I have extracted nodal displacement in my simulation (it is a transient simulation) in /post 26. I usually save the result (as .exel or .txt) from time history post processing manually by copying and pasting. Is there a way to save the result using apdl code?nThanksn -
October 30, 2020 at 1:22 pm
Govindan Nagappan
Ansys EmployeeHi @roshanpj4nYou can copy the /POST26 variable into an array using VGET, and then write that array to a text file using either *MWRITE or *CFOPEN, *VWRITE, and *CFCLOS (see respective documentation in Commands Reference - https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/ans_cmd/Hlp_C_CmdTOC.html ).n
- The topic ‘Save ansys result file, apdl code’ is closed to new replies.
1306
