April 15, 2024 at 3:09 pm
Abhemanyu Palaniswamy Chandrasekaran
SubscriberHello, I am setting up a FSI simulation in LS dyna using the S-ALE solver. I would like to set up a coarse mesh for the fluid domain and refine it dynamically, near the Lagrangian structure to which the fluids are coupled(*CONSTRAINED_LAGRANGE_IN_SOLID).
The sphere inside is a lagrangian structure (PID=1). I want the S-ALE mesh elements close to the sphere to be refined dynamically.Â
I have tried the following using *CONTROL_REFINE_ALE keycard
I have set up a Pressure based refinement condition with the Reference value as 0 so that all ALE solid elements that are coupled to the lagrangian sphere can be refined.
MMSID=3 is a MULTI_MATERIAL_GROUP_SET containing all the MM groups in the model (Air and Water).Â
I get the following error when including this keycard to refine the ALE mesh, whereas the solution works fine without the *CONTROL_REFINE_ALE keycard.Â
Could someone please explain if there is a possible solution to this error or if there are mistakes in my model definition.
Thanks in advance!
April 15, 2024 at 8:58 pm
Alex Rycman
Ansys EmployeeHello Abhemanyu,
As far as I am aware, *ALE_STRUCTURED_MESH does not support *CONTROL_REFINE_ALE. Please look at *ALE_STRUCTURED_MESH_REFINE.Â
Please let me know if that helps.Â
Thank you,
Alex -
April 16, 2024 at 8:30 am
SubscriberHello Alex,
Thank you for the clarification.
I did have a look at *ALE_STRUCTURED_MESH_REFINE keyword.
As mentioned in the manual, this keyword refines the entire S-ALE mesh, whereas I want only the Solid ALE elements close to the Lagrangian sphere to be refined into smaller elements. Is there some other method to do this?
- The topic ‘S-ALE mesh refinement’ is closed to new replies.
