December 28, 2021 at 6:25 am
hkanakri
SubscriberHello,
I am trying to run Ansys Electronics Desktop 2021R2 on Linux OS. I have two questions:
1- Missing "ansysedt" file to run the AEDT from Linux terminal; I have Ansys EM 2021R2 installed. What would be the problem?
2- I can run Ansys 2021R2 workbench on Linux. Is there anyway to open the AEDT from workbench?
I have academic license and multiple versions of AEDT (2019 and 2021) . In fact I can run the 2019 AEDT from Linux terminal using the command "./ansysedt".
Thank You,
Haitham
January 3, 2022 at 9:50 pmANSYS_MMadore
Forum Moderator1) This could be due to your install not being successful. You should see ansysedt within /AnsysEM/AnsysEM21.2/Linux64 and you would run with ./ansysedt
2) If you have integrated AEDT with Ansys you can, but you'll end up with a project that must always be run with Workbench rather than standalone AEDT.
Viewing 1 reply thread- The topic ‘Running Ansys Electronics Desktop 2021R2 on Linux OS’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
Top Contributors-
3882
1414
1241
1118
1015
