May 15, 2020 at 9:51 am
HARISANKER
SubscriberSir,
While doing fine mesh my ansys software is taking too long. It is not the problem of my laptop processor. My laptop has the minimum requirement to run the program.
Also while doing ansys my intel processor is running instead of my Nvidia. And the colour of my ansys workbench icon is grey instead of yellow.
Hope you will resolve my problem.
Thanking you.
May 15, 2020 at 10:40 am
Forum ModeratorPlease define "too long", this is engineering software and runs routinely take hours, days and (for CFD) weeks. Depending on your settings there may not even be a solution.Â
The Student licence entitles you to run on the cpu, not the gpu so I wouldn't expect the graphics card load to be high.Â
May 15, 2020 at 10:59 am
HARISANKER
SubscriberSir,
I was only doing a structural analysis of a simple geometry. I provided the mesh size as 50mm. Then also it was taking hours . Is there a way to change the load from intel to gpu. Is it logically correct to wait for days for analyzing a simple geometry?
What if we needed it urgently?
- The topic ‘RUN TIME DURATION’ is closed to new replies.
6745
1324
1047
