October 4, 2021 at 6:59 am
jerom26
SubscriberHello everyone,
I have a question regarding my failed run.
It doesn't give any errors or reasons why it shouldn't run...
It's from the Ansys Forte tutorial of a multi-cylinder engine.
Does anyone know what might've happened?
The log doesn't say anything, no errors.
When I submit, the file says prepared, running and after 2 seconds failed.
Thanks a lot in advance!
Sincerely,
Jerom Mestrum
October 15, 2021 at 3:40 pmRK
Ansys EmployeeHello Jerom,
We are looking into this, we will get back to you.
October 21, 2021 at 4:20 pmOctober 26, 2021 at 9:07 amjerom26
SubscriberHello RK
I found out that I ran on to many cores.
We only have a license for running on 4 cores. Looking into the log I found out.
Thanks either way!
Viewing 3 reply threads- The topic ‘Run failed in Ansys Forte’ is closed to new replies.
Innovation SpaceTrending discussions- JACOBI Convergence Issue in ANSYS AQWA
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
Top Contributors-
4597
1495
1386
1209
