TAGGED: ansys-fluent-meshing, impeller, meshing, rotor
November 27, 2024 at 8:32 am
November 27, 2024 at 9:40 am
Forum ModeratorAs it's a poly-hexcore you need to check the Ortho-skew/quality. You also need to consider the "other" mesh that the rotor is linked to: how good is that?
November 27, 2024 at 9:45 am
aagalvez
SubscriberHi rob. Thanks for your reply. The min ortho quality for the rotor mesh is 0.2569 while the max skewness is 0.8319. Other domain (stator outlet and inlet) meshes linked with this domain tends to have the same min ortho qual equal to approx 0.25 (for outlet) and 0.5 for inlet. Skewness are lower for the other 2 domains around 0.5 value. Is this good? Thank you.
November 27, 2024 at 10:09 am
Forum ModeratorCell quality looks good. Now how do the flow gradients look. Judging mesh quality (especially resolution) is much harder and generally happens after the run.Â
November 27, 2024 at 10:10 am
aagalvez
SubscriberI didnt try to simulate it yet. I will keep you posted on this. Thank you.
5809
