December 12, 2024 at 7:28 am
dharanimoka
SubscriberHello, I have been trying to design an Induction machine with1474 rpm rated speed. After designing the machine and after putting all the calculated values such as stator and rotor diameter, slot dimension and winding design. Once I run the setup, the r̥āted speed comes down to 1429 rpm.
Can someone explain me what is it that I am doing wrong or what is happening here?
Thank you.
December 12, 2024 at 4:01 pm
MirandaH
Ansys EmployeeHi, you can change the load type to const speed. Analysis->Setup. In the pop up window of Properties, General tab->Load Type->Const Speed->OK. -
December 13, 2024 at 7:19 am
dharanimoka
SubscriberHi, thanks for replying. Now the system is working at rated speed.
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- Calc Error in Field Calculator after PyAEDT Analyze
- Co-simulation in Q3D, Icepak – meshing problem
- Classic Icepak – clarifications on Boundary condition
- Link the Circuit to 3D Terminals
- Rectangular Coil in Maxwell for WPT using solid block
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
1494
1386
1209
