December 12, 2024 at 12:01 pm
deepesh.p.gurdasani
SubscriberHow to model rivet and double rivet joint? Can we use beam connection? Or if in 3D, what contacts to be given ?
December 12, 2024 at 1:59 pm
December 13, 2024 at 12:48 am
deepesh.p.gurdasani
SubscriberThanks for link of discussion. Can we use beam connection instead of 3D rivet?
December 13, 2024 at 12:55 pm
Deepak
Ansys EmployeeFor double rivets, using a beam connection is not a feasible option.
December 13, 2024 at 1:11 pm
deepesh.p.gurdasani
SubscriberFor double riveted, we have to mandatorily go ahead with the 3D model and connections ? Or anyother method similar to beam connection ?
December 13, 2024 at 1:13 pm
Deepak
Ansys EmployeeYou can try with 1D line Elements.
December 13, 2024 at 1:31 pm
deepesh.p.gurdasani
Subscriberok. But in beam connection we get to choose the surface areas of imprints , right ? so on first plate top and second plate bottom, both the areas can be selected. Any specific reason that this wll give incorrect answer?
December 13, 2024 at 1:33 pm
Deepak
Ansys EmployeeYou cannot scope the beam connection to the middle plate in a Double rivet Joint.
December 13, 2024 at 1:56 pm
deepesh.p.gurdasani
Subscriber'Scope to the middle plate'? There are only two plates that we are considering here, right?
December 13, 2024 at 1:59 pm
December 13, 2024 at 2:07 pm
deepesh.p.gurdasani
SubscriberThanks for the clarification. Also IF we consider Butt joint, we should use 'Extract' option in spaceclaim to convert rivet into line body, right? in this case, we will have to remove rivet head and tail parts, right because those parts wont be converted into 1D.
December 13, 2024 at 2:59 pm
Deepak
Ansys EmployeeYes, you are right.
December 14, 2024 at 3:07 pm
deepesh.p.gurdasani
SubscriberAlso, for Riveted butt joint, The contacts to be given to 1D elemnt would be same as the link mentioned by you in one of the above messages ?
Here, upper vertex of 1D element to upper surface (Or projected surface of the head that was removed) on the plate – Frictional
1D element shank to holes of “only” “middle plate” (As first and third plate will have contact with the vertex of 1D element) – Frictional
Lower vertex of 1D element to third plate’s surface (Or projected surface of the tail that was removed) – Frictional
AND Contacts between 1st to 2nd plate & 2nd to 3rd plate – Frictional
Is it correct?
December 17, 2024 at 7:13 pm
deepesh.p.gurdasani
SubscriberIf anyone can guide?
Thanks in advance.
December 18, 2024 at 9:28 pm
deepesh.p.gurdasani
SubscriberIs there a need to create separate post for this query ?
December 19, 2024 at 7:22 am
Deepak
Ansys EmployeeHi,
Sorry for the delay in my response,
You may define the MPC contact between vertex and head imprints. The remaining contacts are correct.
Thanks,
Deepak
December 19, 2024 at 1:34 pm
deepesh.p.gurdasani
SubscriberThanks for your response. MPC won't work for 'Frictional'. MPC is only working in 'Bonded'. In real scanario the head and tail of rivets are to be in contact as 'Frictional', right ?
December 19, 2024 at 1:56 pm
Deepak
Ansys EmployeeNow you replaced the head with a 1D element, bonded contact would be a better option.
December 19, 2024 at 2:05 pm
deepesh.p.gurdasani
SubscriberAny specific reason for that, Deepak? because real scenario wouldn't have bonded contact with the plate.
December 19, 2024 at 2:15 pm
Deepak
Ansys EmployeeFrictional contact is a nonlinear contact type and is slightly more computationally expensive than linear contacts like bonded or no separation. However, using a linear contact in place of a frictional one in such scenarios would be an oversimplification and could adversely impact the accuracy of the results.
December 19, 2024 at 2:55 pm
deepesh.p.gurdasani
SubscriberOk. I tried this. Till I am using 'Force' as a load, this runs ok but as soon as I change/apply it to 'acceleration', it shows error "Internal magnitude exceeded' .
December 19, 2024 at 3:01 pm
Deepak
Ansys EmployeeMake sure the model is constrained properly.
Can you share any screenshots of the model?
December 19, 2024 at 3:03 pm
December 19, 2024 at 4:06 pm
Deepak
Ansys EmployeeLet me try it at my end.
December 20, 2024 at 1:09 pm
deepesh.p.gurdasani
SubscriberHello Deepak, did you try?
5774
.png)
