October 21, 2024 at 6:20 pm
ivan.beltracchi
SubscriberHi everyone. While I was uploading a mesh in Fluent, the software crashed for a few seconds and after that the ribbon window and the console disappeared. I've also tried to upload the file again in a second moment using the Fluent in standalone, but the problem still persists.Â
Could someone suggest me how to solve this problem and restore the default windows?
October 22, 2024 at 10:36 am
Forum ModeratorThat's new. There's a folder in %appdata% for Ansys, possibly a couple. Close Fluent and any other Ansys products then rename that/those folders.Â
October 23, 2024 at 8:34 pm
ggege0524
SubscriberI have the same problem. I searched for  %appdata% and there was one folder called Ansys. I renamed it to Ansys_old, and reopened the Fluent, but that didnt solve the problem.Â
October 24, 2024 at 2:51 pm
George Karnos
Ansys EmployeeHello,
Try the following:
1. Rename the %APPDATA%\Ansys directory to Ansys_old1
2. Run Programs->Ansys 2024 R2->Product & Cad ConfigurationChoose: Unconfigure Products & Cads
After that finishes, Choose:
Configure Products & CadsAfter that is finished, exit and try to run. Does this allow the Ribbons to appear?
Best Regards,
George -
October 24, 2024 at 10:19 pm
ggege0524
SubscriberNope, it still doesn't work. I even tried it twice.Â
I had already two folders Ansys and Ansys_old ( I renamed it yestarday, after reading Rob's thread).Â
Then, today i renamed both of them, and now I have four files, see below.Â
Then I unconfigured and reconfigured Products and Cads. You can tell that something changed, because I get the same notifications, I got when i installed Ansy for the first time ( like choosing the theme for example), but the ribbon is not there. If you right click in Fluent, it offers you different options, like console, workflow, task page,etc, but the option ribbon is grayed out.
October 31, 2024 at 11:54 am
George Karnos
Ansys EmployeeWhen you renamed the %APPDATA%\Ansys folder, were all Ansys programs closed?
If Fluent was still open when %APPDATA%\Ansys was renamed, it could still write incorrect setup information to it.Also, has anything changed as far a graphics goes?
Has the resolution changed? -
October 31, 2024 at 12:16 pm
George Karnos
Ansys Employee -
October 21, 2025 at 4:41 pm
kalavag
SubscriberI have the same problem, I haven't been able to solve it.Â
October 22, 2025 at 8:34 am
Forum ModeratorTry the solution on here https://innovationspace.ansys.com/forum/forums/topic/missing-task_bar-in-ansys-fluent/
5899
1306
