TAGGED: aerodesign, distributed, excel, imported-load, wing
September 18, 2024 at 3:49 am
a.dourado
SubscriberHi,Community
I would like to present an analysis of a wing rib in Ansys Mechanical, in hope that the tools used here may help others with similar problems. The material selected for this analysis is Balsa Wood, with properties obtained experimentally.To begin with, we should prepare our geometry. In this study case, the rib will be analyzed as a 2D surface element.OBS: It's important that the surface is on one of the main planes of the respective coordinate system, as shown.
Once the geometry is ready, the mesh should be generated. The element chosen was triangular, with a sizing applied of 2mm, providing an average element quality of 0.96, with a low standard deviation.
Next, we have to apply the boundary conditions, and the loads. For the boundary conditions, the rib was considered fixed in the rectangular cut made on it, where the wing spar is meant to be. For the load, an imported load given by a .tsv file, based on a spreadsheet, was used to apply the lift distribution in the rib. To couple the load given by the tsv file with Ansys Mechanical, it was necessary to use the "External Data" module in Ansys Workbench, and link it to the "Static Structural" module.
Finally, we were able to generate the results of the analysis. In addition, the results should be validated through structural testings performed on real ribs.
September 19, 2024 at 8:48 am
Ashish Khemka
Forum ModeratorThanks, for sharing this!
Ashish Khemka
- The topic ‘Rib Structural Analysis of an Aerodesign Aircraft Wing’ is closed to new replies.
- Stopping simulation automatically at composite failure based on displacement
- QuartodiLitro Motostudent | Fork feet analysis and optimization
- E-Racing Bergamo | Chassi’s torsional deformation
- Tress structural´s simulation using carbon fiber tubes
- CFD Simulation (Fluent) on Brazil FSAE CAR (FORMULA UFPB)
- Mission to Launch: Precision Engineering at UPC Space Program with Ansys Simulat
- Transmission System Development (Structural Simulation) Protto UFSC Motorsport
5844
