February 14, 2019 at 4:22 pm
abbas
SubscriberHello everybody,
I am working on the pipe that high pressure and temperature CO2 (P=9Mpa and T=310K) enters into the pipe and with pressure (P=5Mpa) exits.Â
My question is: I create a Homogenous binary mixture. In my domain, at the inlet, I have supercritical CO2 (neither liquid nor vapor). So, for the inlet, I have to specify mass fraction at the inlet. What would be the mass fraction?
I checked my model. I tried with pressure and temperature below supercritical, P=6Mpa and T=290K and quality of CO2=0.5. The simulation converged. So I think the problem should be related to the supercritical parameters.
Any suggestion about setting supercritical parameters in the inlet and two-phase at the outlet?
Best regards
Abbas
February 14, 2019 at 8:05 pm
Amine Ben Hadj Ali
Ansys EmployeeHave you tried with one? The interpolation should take care whether pressure above or below pcrit.
February 14, 2019 at 10:04 pm
abbas
SubscriberHello Amine,
What do mean with one? Do you mean that one of the inlet valve (either pressure or temperature )above the critical and another below the critical point?
Thanks
February 15, 2019 at 8:20 am
Amine Ben Hadj Ali
Ansys EmployeeI meant mass fraction equal to one at inlet.
February 15, 2019 at 2:50 pm
February 16, 2019 at 9:25 am
Amine Ben Hadj Ali
Ansys EmployeeWhich error? -
February 17, 2019 at 2:14 am
abbas
The error was outflow.
However, I just tested a simple pipe that inlet pressure is 8Mpa and inlet temperature is 305K and the outlet pressure is 7Mpa and wall temperature is 290K. I want to see that CFX is able to solve this problem or not. Now, my RGP table boundary for pressure is 0.5Mpa to 50Mpa and temperature is 250K to 550K but it says that "Table bounds warnings at: END OF TIME STEP". How is it possible?
Best regards
Abbas
February 17, 2019 at 6:29 pm
Amine Ben Hadj Ali
Ansys EmployeeThis might be possible whenever within the AMG iterative solver the dependent variable to calculate he properties are out of bounds. This might disapper at the flow evolves but might indicate wrong settings, time scale size or even small table.
February 17, 2019 at 6:30 pm
Amine Ben Hadj Ali
Ansys EmployeeAnd Outflow, as error is manifold, might have several roots.
February 18, 2019 at 2:56 pm
abbas
SubscriberÂ
The problem cannot be the size of the table because the lower and upper table size for pressure and temperature are 0.5Mpa to 50Mpa and temperature is 250K to 550K and the simulation domain is a simple pipe that has one inlet and one outlet that inlet pressure is 8Mpa and inlet temperature is 305K.
February 18, 2019 at 3:34 pm
Amine Ben Hadj Ali
Ansys EmployeeSo what do you think the issue is related to? As I said a super-critical Fluid is treated as being vapor.
February 18, 2019 at 3:51 pm
abbas
SubscriberThe only warning that I am receiving is "Table bounds warnings" but I am pretty sure that all domain properties are inside the table.
Best regards,
Abbas
February 18, 2019 at 6:22 pm
Amine Ben Hadj Ali
Ansys EmployeeI am sorry but cannot debug further here if you are not providing any other info. Even if you think your pressure and temperature field are within the range of the table by iterating and interpolating from IP to Nodes and doing bi-linear and tri-linear operations somethings the variable are out of bounds. The whole issue might be related to something else which I cannot figure it out without any other further statements: material, boundaries, models... You can attach the definition file here perhaps some other forum members (NON-ANSYS-STUFF) can have a look into it.
February 18, 2019 at 7:23 pm
abbas
SubscriberThanks for your help.
I am wondering how is it possible (# case 1) for the initial condition below the critical point, simulation for simple pipe is working but for (# case 2) initial condition upper critical point I got the overflow error (when I choose homogenous binary mixture for both cases). Also, when I choose initial condition upper critical point and choose just one material (vapor CO2) the simulation is working.Â
Best regards
Abbas
February 18, 2019 at 7:52 pm
Amine Ben Hadj Ali
Ansys EmployeePlease add information about the boundaries used as well as the material. I will then check on my side.
February 18, 2019 at 8:32 pm
February 19, 2019 at 7:25 am
Amine Ben Hadj Ali
Ansys EmployeeHi it is working for my simple pipe case with 0.5 MPa @ Inlet / 350 K, Operating Pressure 7 MPa.
@310K total temperature: one can notice that the run is not stable as the static temperature might be below the dome and the calculation is not so "easy" anymore. That is the region where the liquid become supercritical. But again it runs (simple test).
February 19, 2019 at 12:25 pm
abbas
SubscriberThanks Amine
Could you give me some screen shot from your simulation such as default domain and inlet and outlet setting and also number of mesh and length and width of the tube.
Best regards
Abbas -
February 19, 2019 at 1:13 pm
February 19, 2019 at 6:14 pm
abbas
Thanks for your help. I looked into your model, we both do the same procedure but I got the Floating point exception: Overflow. I think the problem should be meshing. But, I generate mesh in ICEM that quality of mesh is between 0.75 to 1 and Orthogonal Quality higher than 0.78. Here I attached the mesh of the pipe.
best regards
Abbas
February 19, 2019 at 6:25 pm
Amine Ben Hadj Ali
Ansys EmployeeDo you get overflow even if you set higher Total Temperature @Inlet?
February 19, 2019 at 6:33 pm
abbas
SubscriberThanks for your quick reply.
Yes. I set 7.5MPa for reference pressure. I set 340K and 0.5MPa for inlet and 0 for outlet. However, I get overflow error.
Best regards
Abbas -
February 19, 2019 at 6:39 pm
abbas
SubscriberThat might not be logical. Can I use your mesh that you generate to see that I am going to the right way?
Best regards
Abbas -
February 19, 2019 at 7:26 pm
Amine Ben Hadj Ali
Ansys EmployeeCan you just use a coarser mesh to check if it is really mesh dependent? Set solver settings to default.
February 19, 2019 at 8:12 pm
February 19, 2019 at 8:22 pm
Amine Ben Hadj Ali
Ansys EmployeeLets check first: You can copy your CCL of all settings (Export>CCL select everything) here so that it can be checked.Â
February 19, 2019 at 8:37 pm
abbas
# State file created:Â 2019/02/19 15
6:28
# Build 19.3 2018-11-16T23
3
6.098000
LIBRARY:
 MATERIAL: CO2
  Binary Material1 = CO2L
  Binary Material2 = CO2V
  Material Group = User
  Option = Homogeneous Binary Mixture
  SATURATION PROPERTIES:
   Component Name = CO2V
   Option = Table
   Table Format = TASCflow RGP
   Table Name = D
cfx/CO2-high.rgp
  END
 END
 MATERIAL: CO2L
  Option = Pure Substance
  Thermodynamic State = Liquid
  PROPERTIES:
   Component Name = CO2L
   Option = Table
   Table Name = D
cfx/CO2-high.rgp
  END
 END
 MATERIAL: CO2V
  Thermodynamic State = Gas
  PROPERTIES:
   Option = Table
   Table Name = D
cfx/CO2-high.rgp
  END
 END
END
FLOW: Flow Analysis 1
 SOLUTION UNITS:
  Angle Units = [rad]
  Length Units = [m]
  Mass Units = [kg]
  Solid Angle Units = [sr]
  Temperature Units = [K]
  Time Units =
 END
 ANALYSIS TYPE:
  Option = Steady State
  EXTERNAL SOLVER COUPLING:
   Option = None
  END
 END
 DOMAIN: Default Domain
  Coord Frame = Coord 0
  Domain Type = Fluid
  Location = SOLID
  BOUNDARY: Default Domain Default
   Boundary Type = WALL
   Location = WALL
   BOUNDARY CONDITIONS:
    HEAT TRANSFER:
     Option = Adiabatic
    END
    MASS AND MOMENTUM:
     Option = No Slip Wall
    END
    WALL ROUGHNESS:
     Option = Smooth Wall
    END
   END
  END
  BOUNDARY: OUT
   Boundary Type = OUTLET
   Location = OUT
    FLOW REGIME:
     Option = Subsonic
    END
    MASS AND MOMENTUM:
     Option = Static Pressure
     Relative Pressure = 0 [Pa]
    END
   END
  END
  BOUNDARY: inlet
   Boundary Type = INLET
   Location = IN
    COMPONENT: CO2V
     Mass Fraction = 1
     Option = Mass Fraction
    END
    FLOW DIRECTION:
     Option = Normal to Boundary Condition
    END
    FLOW REGIME:
     Option = Subsonic
    END
    HEAT TRANSFER:
     Option = Total Temperature
     Total Temperature = 350 [K]
    END
    MASS AND MOMENTUM:
     Option = Total Pressure
     Relative Pressure = 0.5 [MPa]
    END
    TURBULENCE:
     Option = Medium Intensity and Eddy Viscosity Ratio
    END
   END
  END
  DOMAIN MODELS:
   BUOYANCY MODEL:
    Option = Non Buoyant
   END
   DOMAIN MOTION:
    Option = Stationary
   END
   MESH DEFORMATION:
    Option = None
   END
   REFERENCE PRESSURE:
    Reference Pressure = 7.5 [MPa]
   END
  END
  FLUID DEFINITION: Fluid 1
   Material = CO2
   Option = Material Library
   MORPHOLOGY:
    Option = Continuous Fluid
   END
  END
  FLUID MODELS:
   COMBUSTION MODEL:
    Option = None
   END
   COMPONENT: CO2L
    Option = Equilibrium Constraint
   END
   COMPONENT: CO2V
    Option = Equilibrium Fraction
   END
   HEAT TRANSFER MODEL:
    Include Viscous Work Term = True
    Option = Total Energy
   END
   THERMAL RADIATION MODEL:
    Option = None
   END
   TURBULENCE MODEL:
    Option = k epsilon
   END
   TURBULENT WALL FUNCTIONS:
    High Speed Model = Off
    Option = Scalable
   END
  END
 END
 OUTPUT CONTROL:
  RESULTS:
   File Compression Level = Default
   Option = Standard
  END
 END
 SOLVER CONTROL:
  Turbulence Numerics = First Order
  ADVECTION SCHEME:
   Option = High Resolution
  END
  CONVERGENCE CONTROL:
   Length Scale Option = Conservative
   Maximum Number of Iterations = 100
   Minimum Number of Iterations = 1
   Timescale Control = Auto Timescale
   Timescale Factor = 1.0
  END
  CONVERGENCE CRITERIA:
   Residual Target = 1.E-4
   Residual Type = RMS
  END
  DYNAMIC MODEL CONTROL:
   Global Dynamic Model Control = On
  END
 END
END
COMMAND FILE:
 Version = 19.3
END
Best regards,
Abbas
February 19, 2019 at 9:37 pm
Amine Ben Hadj Ali
Ansys EmployeeI do not see any issues: I do not think it is mesh-related. Perhaps it has to do with the RGP tables. Another thing: Please enable beata feature and set for liquid component "subcooled". You are registered without a university mail address so that I won't able to dig deeper here.
February 19, 2019 at 9:41 pm
abbas
Now I change my email to university email address. Could you let me know how I can set liquid component "subcooled"?
Best regards,
Abbas
February 20, 2019 at 2:10 pm
abbas
SubscriberThanks, Amine.
The problem was just subcooled. I hope others who have this problem could find this page.
Best regards
Abbas
February 20, 2019 at 2:16 pm
February 20, 2019 at 2:23 pm
abbas
SubscriberThanks again and yes this is good to see that mesh is not the problem. I marked as the problem is solved.
Best regards
Abbas
- The topic ‘RGP table for supercritical, gas and liquid phase’ is closed to new replies.
4858
1587
1386
1242
