July 6, 2023 at 2:06 pm
SAEED OMAR
SubscriberHi
I have a question regarding SBR+ in HFSS, I am wondering how accurate the result i get from SBR+ regarding return loss (S11). I trties to compare the return loss if high frequency antenna (100 GHz) using FEM and SBR+ and they are different.
thanks
July 7, 2023 at 2:40 pm
Faezeh Tork Ladani
Ansys EmployeeHi Saeed,
The question is so general and I am not sure what sort of setup you are using. In general, note that SBR+ is an asymptotic solver and suitable for electrically huge scatterers. If it is used properly based on SBR+ assumptions, we get very good agreement with full wave simulations, in much shorter time!
If you'd like us to investigate your design, file a support ticket through customer portal. If you don't have access to portal, you may share some more information here and we will help within the scope of this forum.
- The topic ‘return loss using SBR+’ is closed to new replies.
5779
