TAGGED: cfd-post, fluid, licensing, modal-analysis, post-processing
December 16, 2021 at 8:22 am
jerom26
SubscriberHello everyone,
When I have a Forte ft.ind results file and try to load it into CFD-post, this happens....
ERROR
Error reading file 'C:/Jerom/Ansys/Projecten/2021 R2/Stap 3 simulaties/EmmerickSolved/Ansys Cloud drive/ForteProject_2.analysis/Nominal/Nominal.ftind':
Error opening file C:/Jerom/Ansys/Projecten/2021 R2/Stap 3 simulaties/EmmerickSolved/Ansys Cloud drive/ForteProject_2.analysis/Nominal/Nominal.ftind.
Reason: The Forte results reader couldn't be initialized.
Does anyone know how to fix this error?
Thanks a lot!
December 17, 2021 at 8:02 pmRK
Ansys EmployeeHello,
Can you please save the files in a different location and try again? A different drive, if possible.
December 20, 2021 at 1:20 pmDecember 20, 2021 at 1:35 pmjerom26
SubscriberSome extra information...
In the command window of CFD-Post it said the following:
cgio_open_file:ADF 16: Internal error: Memory boundary tag bad.
Viewing 3 reply threads- The topic ‘results reader couldn’t be initialized’ is closed to new replies.
6535
1311
