June 9, 2020 at 10:24 am
mubasherrasheed70
Subscriberi have problem to discuss. I am doing multiphase problem where i have to go through 30-40k iterations for the results. but every time i export results as case and data, they are not save. Every time i close fluent i lost my iteration results. Kindly suggest me a way to save my results as animations and plots.
June 9, 2020 at 12:05 pm
Karthik Remella
AdministratorI'd strongly recommend writing your animation and report plots. If you do not write the report plots, they are stored in the memory. Once you close Fluent, these are removed and therefore you will not be able to bring them up. When you write out these files, they are saved on the harddrive. You should be able to reuse the data by asking Fluent to read the data and generate your plots.
I hope I have interpreted your question correctly. If this is not the case, please let me know and I'd be happy to help.
Thank you.
KarthikÂ
June 10, 2020 at 9:04 pm
mubasherrasheed70
Subscriberthank you it helped
- The topic ‘results after iteration are lost every time i close the fluent’ is closed to new replies.
6379
