Restarting last converged load step without full solve
    • doronef
      (Pic fo attention)
      hi, i am trying to restart analysis after stopping solution mid-way, i have checked restart points after each load step and "save after full solve" is set to ON.
      how can i recover the restart point after a succesfull load step?
      If you have set the Restart Controls as shown below, then at the top of the Analysis Details window, set the Restart Type to Manual and select the Current Restart Point.  In this example, the analysis originally had 1 load step, which solved.  I changed it to 2 load steps so I could change the force solved in load step 1 to a new value in load step 2 and start the solution from the end of load step 1.
