December 18, 2024 at 12:54 pm
valerym.m5
SubscriberGood afternoon,
I am trying to master switching the solver type (Implicit => Explicit ) during the calculation
according to the tutorial example https://www.dynaexamples.com/implicit/basic-examples/impl-expl-switch
I made a model problem - see https://drive.google.com/file/d/1nPr6MEym33FCajFMf6DglQeOF-cdUzxk/view?usp=sharing
I created a curve to output the calculation results
but at the stage of using the explicit solver, the results are written with "other" steps - not at all what I ordered in the curve
the first step of outputting the results is 1.105 - 1.005 = 0.1 seconds
then the output step is 0.00003 seconds
but it should have been at the stage (1.005 - 1.006) = 1E-5 seconds
If someone has already encountered this problem - write what the problem is and how to get calculation results with the required time step?
December 18, 2024 at 5:52 pm
valerym.m5
SubscriberÂ
Is it possible to perform stress simulation for a material with viscous properties (mat 269 or 318 or “external” models of materials from PolyUmod) using a full restart?
Step 1 – static loading – implicit solver
Step 2 – dynamic loading – explicit solverIf anyone has such an example – I will be glad to get acquainted with such models.
I tried to perform stress simulation using "external" material models from PolyUmod using a full restart , unfortunately my attempts were not successful.
The reason is that LS-DYNA could not read the calculation results from the first (static) step, for parts using the above materials.
