March 8, 2024 at 4:42 pm
mohammed.ismail.ul.haq
I have an issue with INISTATE command in Ansys Mechanical apdl, where i apply linear varying stress i tried checking through Inistate list command , but the stress dont seem to vary linearly , not sure how to go about, the task is LTB check in angled section non linear.
i am not sure about the entire code as well am i progressing in right direction , plus the code works in only this specific order other wise ansys crashes , I need any tips on how to progress , BMD for Solid to get critical moment MCR. IF posssible please let me know how to improve the code as well.
!!=======Material parameters (steel)==========
/CLEAR,START
/FILNAME,L_section,1
/UNITS,SI
/COM, Structural
E_STEEL=2.1e11 !n/m^2
NU_STEEL=0.3
DENS_STEEL=7850
f_y =235000000 !n/m^2
!!========Modelling=========
!*clear
/prep7
!!======Element Type=======
ET,1,SOLID186
!DOF,UX,UY,UZ,ROTX,ROTY,ROTZ
!!=======Material Properties=======
mp,ex,1,E_STEEL
mp,prxy,1,NU_STEEL
mp,dens,1,DENS_STEEL
!!========Geometric properties=======
Total_Length=1 !!!LENGTH 1M
Length_leg= 0.25 !!!EQUAL ANGLED
Thickness_leg=0.02 !!!THICKNESS OF LSECTION
Radius_1=0.018
Radius_2=0.009
!!========Define keypoints========
k,1,0,0,0
k,2,Thickness_leg,0,0
k,3,Length_leg,0,0
k,4,Length_leg,Thickness_leg,0
k,5,Thickness_leg,Thickness_leg,0
k,6,Thickness_leg,Length_leg,0
k,7,0,Length_leg,0
k,8,0,Thickness_leg,0
!!========Lines=========
LSTR, 7, 6
LSTR, 7, 8
LSTR, 5, 6
LSTR, 8, 1
LSTR, 1, 2
LSTR, 5, 4
LSTR, 4, 3
LSTR, 3, 2
LFILLT,1,3,Radius_2,0,
LFILLT,6,7,Radius_2,0,
LFILLT,3,6,Radius_1,0,
GPLOT
!!=========Area=========
LSEL,S,LINE,,1,11 !!(AL COMMAND NOT WORKING SO USING LSEL TO SELECT ALL LINES AND PLOTING AREA)
AL,ALL
ALLS
!!========Extrude Volume========
VEXT,1, , ,0,0,Total_Length,,,
ESYS, 0
!!=======Meshing========
ASEL,S,AREA,,1,2,1
!AESIZE, ALL, LENGTH_LEG/50,
AESIZE, all, Length_leg/50,
ALLSEL,ALL
EXTOPT,VSWE,AUTO,0 !SPECIFY SOURCE AND TARGET SURFACE FOR SWEEP
EXTOPT,ESIZE,50
TYPE,1
MAT,1
MSHAPE,0,3D
MSHKEY,1
ALLSEL,ALL
Vsweep,ALL,1,2,1
/SOL
! ========Bolts ========
Bolt1_x = Thickness_leg*4
Bolt1_z = Thickness_leg*5
Bolt_dia = Thickness_leg
!BLOCK, Bolt1_x, Bolt1_x+ Bolt_dia,0,Thickness_leg, Bolt1_z, Bolt1_z+ Bolt_dia
Nsel,s,loc,x, Bolt1_x, Bolt1_x+Bolt_dia
Nsel,r,loc,z, Bolt1_z, Bolt1_z+ Bolt_dia
D,ALL,,,,,,UX,UY,UZ
ALLSEL,ALL
Nsel,s,loc,x,(Length_leg-Bolt1_x), (Length_leg-Bolt1_x)+Bolt_dia
D,ALL,,,,,,UX,UY,UZ
ALLSEL,ALL
Nsel,r,loc,z, (Total_Length-Bolt1_z),(Total_Length-Bolt1_z)+ Bolt_dia
D,ALL,,,,,,UX,UY,UZ
ALLSEL,ALL
D,ALL,,,,,,UX,UY,UZ
ALLSEL,ALL
!!====CONSTraints AT EDGE LINE
LSEL,S,LINE,,19,20
NSLL,S,1
D,ALL,,,,,,UX,UY ! should not be ux constrained instead of uz?
ALLSEL,ALL
!!====CONSTARINT AT EDGE LINE
LSEL,S,LINE,,5
LSEL,A,LINE,,8
CM,LINE_1,LINE
CMSEL,S,LINE_1,LINE
NSLL,S,1
D,ALL,,,,,,UX,UY,UZ
ALLSEL,ALL
GPLOT
NSEL,ALL
ACEL,0,-9.8,0
!!====imperfection============
/SOL
antype,static
!PSTRES,1
Outres,all,all
allsell,all
solve
finish
/post1
pldisp,1
finish
/sol
antype,buckle
bucopt,lanb,2
mxpand,2,,,yes
solve
finsh
/post1
set,first
pldisp,1
set,next
pldisp,1
finish
/prep7
upgeom,0.001,1,1,L_section,rst !0.01 is the scale factor which can be varied thus varing geometery
!elastic part
!plastic
TB,BISO,1,1,2
TBTEMP,0
TBDATA,,f_y,0,,,,
!===residual stress========
/SOL
!initial stress for the second part
NSEL,S,LOC,Y,0,Length_leg/2
NSEL,R,LOC,X,0,0.1*Thickness_leg
INISTATE,SET,DATA,FUNC
INISTATE,SET,DTYP,STRE
INISTATE,define,ALL,,,,LINY,(-0.22*f_y),((0.92*f_y)/Length_leg)
!initial stress for the first part
NSEL,S,LOC,Y,Length_leg/2,Length_leg
INISTATE,define,,,,,LINY,(0.73*f_y),((-0.98*f_y)/Length_leg)
!initial stress for the third part
NSEL,S,LOC,X,0,Length_leg/2
NSEL,R,LOC,Y,0,Thickness_leg
INISTATE,define,,,,,LINX,(-0.22*f_y),((0.92*f_y)/Length_leg)
!initial stress for the forth part
NSEL,S,LOC,X,Length_leg/2,Length_leg
INISTATE,define,,,,,LINX,(0.73*f_y),((-0.98*f_y)/Length_leg)
!!===LOADING CONDITIONS=====
force_12 = 5000 ! the value of the load
NSEL,S,LOC,Z,0,0
*GET, N_COUNTz, NODE,,COUNT
load_1=force_12/N_COUNTz
f,all,fz,load_1
allsel,all
NSEL,S,LOC,Z,Total_Length,total_length
*GET, N_COUNTd, NODE,,COUNT
load_2=force_12/N_COUNTd
f,all,fz,-load_2
allsel,all
!===nonlinear analysis============
/sol
ANTYPE,0,new
NLGEOM,1
NSUBST,100,1000,50
NEQIT,1000
OUTRES,ERASE
OUTRES,ALL,ALL
solve -
March 13, 2024 at 9:29 am
Ashish Khemka
Forum ModeratorHi,
When you apply an initial condition then can you try to see if the response is linear for a linear model. For example a bar stretched in elastic region initially will try to regain its shape. Does you see a similar behavior if you simplify the model. This may be a simple check for the model setup.
Ashish Khemka
March 15, 2024 at 5:18 pm
SubscriberAshish Khemka sir , thank you for your reply will try thisÂ
- The topic ‘Residual stress and LTB check’ is closed to new replies.
5674
1890
1419
1304
