Requesting to resolve run-time simulation error, while simulating a built-in example “Trihedral RCS”
May 11, 2021 at 6:18 pm
Preeti
SubscriberMay 13, 2021 at 1:23 pmANSYS_MMadore
Forum ModeratorCan you tell which HPC license you have access to on your license server? Is it anshpc, anshpc_pack, hfsshpc or hfsshpc_pack?
Please adjust your HPC and Analysis Options -> Options to select the appropriate setting for your HPC type.
ANSHPC: HPC License type=Pool; Use legacy Electronics HPC License=False
ANSHPC_PACK: HPC License type=Pack; Use legacy Electronics HPC License=False
HFSSHPC: HPC License type=Pool; Use legacy Electronics HPC License=True
HFSSHPC_PACK: HPC License type=Pack; Use legacy Electronics HPC License=True
May 13, 2021 at 1:51 pmPreeti
SubscriberDear Sir Thank you so much for your help.
Although, I was not able to find out which HPC License I have access to, on my license server (not able to find the option). But, as suggested by you, I have tried changing the following setting "Use legacy Electronics HPC License = TRUE", it worked and I got the simulated results.
I would appreciate if you can tell the reason behind the requirement of above settings. This is because, earlier I was successfully running my other simulations in HFSS, when this setting was FALSE. So, that I can get better insight to when these settings are required to be done.
Regards
Preeti
May 13, 2021 at 1:54 pmANSYS_MMadore
Forum ModeratorPerhaps the license on the server has change, requiring the change to your settings.
May 13, 2021 at 3:22 pmPreeti
SubscriberThank you sir, once again. Your help at every stage is highly appreciated.
Viewing 4 reply threads- The topic ‘Requesting to resolve run-time simulation error, while simulating a built-in example “Trihedral RCS”’ is closed to new replies.
4602
1510
1386
1209
