Request to resolve Eulerian wall film thickness issue in ANSYS Fluent
    • sameerkumarverma1105
      Dear all,
      I am currently using ANSYS Fluent to model a mucus layer in human lung airways using the Eulerian Wall Film (EWF) model.
      I am encountering an issue with film thickness specification and visualization. Although I prescribe different initial film thicknesses (e.g., 25 µm, 300 µm, and 1000 µm), the resulting film height contours appear identical in all cases.
      I would sincerely appreciate any guidance or insights on this issue.
      Thank you very much.
      Regards
      Sameer
      What does the contour look like?
      The first image corresponds to a film thickness of 1500 µm, while the second represents 25 µm. However, both cases exhibit the same physical thickness, with only the color scale changing between the two images.
      Please plot in Fluent. EWF is a wall facet model so only really works when plotted on the walls.
      The mucus layer is physically present within a finite thickness inside the airway wall, so it should appear in an internal cut plane. Will EWF not work for the plane?
      As suggested, I have also plotted in the fluent but same issue is appearing.
      No, EWF is a facet "thin" film model. It has no physical thickness, and shouldn't show on planes other than if there's an image interpolation effect. There's also a numerical cut off for the thickness, but I don't know if you've hit the limiter.
      I have not reached the limiter value, which is set to 0.005 m by Ansys. If possible, could we have a short online meeting to discuss this issue?
      It's not possible - Staff are only able to answer questions and view images on the Forum. Commercial users with the appropriate licences get additional options including calls and our checking models.
      Since the mucus layer is created using the EWF model, it exists only on the inner wall surfaces and not as a volumetric layer.
      Correct.
Viewing 12 reply threads
