July 29, 2023 at 1:27 pm
SIDDHARTH MOHAN
SubscriberHello, I wish to seek some guidance on a modeling issue in Ansys AEDT . I have a section of a cylinder with few elements on it's surface. How can I replicate this section into a complete cylinder ?
Attached is the image of the section.need to change the above into to something like the below :
thanks
July 31, 2023 at 4:14 pm
Praneeth Munaga
Ansys EmployeeHi Siddharth,
Thank you for reaching out to the Ansys learning forum.
Please create a new relative coordinate system at the center of the circular cross-section of the cylinder. Then duplicate around the axis which is along the cylinder length. Kindly check "Creating an Offset Relative CS" and "Duplicating Objects Around an Axis" sections of the HFSS help document accessible under the Help menu.
Best regards,
Praneeth. -
July 31, 2023 at 4:20 pm
SIDDHARTH MOHAN
Subscriberthanks for the reply Praneeth, is there a circular co-ordinate system in AEDT like other Ansys Mechnical tools ?
regards
July 31, 2023 at 4:34 pm
Praneeth Munaga
It is possible to define the points for creating objects using either the cylindrical or spherical coordinate systems in addition to the cartesian coordinate system in the status bar of the AEDT interface. Please go through "Defining Cylindrical Coordinates" and "Defining Spherical Coordinates" sections of the HFSS help document.
Best regards,
Praneeth. -
July 31, 2023 at 9:03 pm
August 1, 2023 at 3:49 am
Praneeth Munaga
The gap you are seeing is just because of the rendering. By default, optimistic rendering is selected for a smooth user experience. You can change this by going to View menu>Render>Enhanced display and change the settings appropriately to see the outcome. After verification, you can toggle back to normal settings.
Best regards,
Praneeth. -
August 1, 2023 at 4:00 am
SIDDHARTH MOHAN
Subscriberthanks for the reply and if it’s not a rendering issue then what other things can I try ? I don't see any changes even after turning on rendering enhancement.
August 1, 2023 at 4:25 am
Praneeth Munaga
Ansys EmployeePlease make sure that the center and radius of the arc match exactly with that of the cylinder cross-section.
August 1, 2023 at 4:32 am
August 1, 2023 at 4:59 am
Praneeth Munaga
Ansys EmployeeOne general piece of advice would be to see if the arc is correctly defined or not. If it is correctly defined, then its ends will coincide exactly after duplicating around the axis.
Please provide details on what you mean by increasing the thickness of the circle.
August 1, 2023 at 5:17 am
August 1, 2023 at 6:52 am
Praneeth Munaga
Ansys EmployeePlease check if you are increasing the thickness on one side or both sides. For your case, it should be on one side only (+ve side).
August 1, 2023 at 7:12 am
August 1, 2023 at 7:19 am
Praneeth Munaga
Ansys EmployeeAre you not trying to unite these arcs? If so, that would not matter. If you don't want to unite, then please check the first arc that you created. It is modified or not created properly. Any circular arc will have ends like the one you drawn using the thicken sheet unless it is modified. Hope this helps.
August 1, 2023 at 7:25 am
SIDDHARTH MOHAN
Subscriberthanks for the reply , will you be able to have a look at it and suggest best route ahead if I share the workspace?
August 1, 2023 at 7:35 am
Praneeth Munaga
Ansys EmployeeThe Ansys personnel cannot access any of the attachments in the forum. I would recommend you to check with your seniors or tutors in your university who can guide you on the same.
August 1, 2023 at 7:38 am
August 1, 2023 at 10:58 am
SIDDHARTH MOHAN
SubscriberBased upon the previous snapshot it will be great if you can share your thoughts on how this kind of an arc can be completed to form a cylinder ?
August 1, 2023 at 12:46 pm
Praneeth Munaga
Ansys EmployeePlease provide more details on how the first arc is created. If possible, also provide details of the model and design type you are creating to help us serve you better.
Kindly note that you can use Boolean subtract of the second arc from the first arc to create the required edge.
August 1, 2023 at 3:09 pm
SIDDHARTH MOHAN
Subscribersorry but I don't have the details of how the original arc was created. The cylindrical arc with the patch elements was optimized for performance as an antenna and now this section of the arc needs to be completed into a full cylinder replicating the path elements on the arc to form a cylindrical antenna array. I had shared the below image in original message in this chain to given an idea on how the cylindrical array with the elements replicated may look like.
August 1, 2023 at 3:19 pm
Praneeth Munaga
Ansys EmployeeIn that case, it may be required to connect (unite) these arc elements. Or, you delete the intersecting portions. Please use which ever option helps you.
August 1, 2023 at 3:36 pm
SIDDHARTH MOHAN
Subscriberthe image sent in the previous message was just to give an idea on the design type I am trying to create as it was asked. I just mirrorred the original arc to create that snapshot for understanding. The arcs don’t align at the bottom to form a proper cylinder otherwise I would have united them long back…
It’s not an arc with cental angle of 120deg such that I can hook three of these together to form a proper cylinder.
August 1, 2023 at 4:12 pm
Praneeth Munaga
Ansys EmployeeSince you are forming an array or patch elements, the separation between the end elements of the two consecutive arcs should be equal to that of the consecutive elements in a single arc (unless your design specifications differ). So, the extra blank spaces at the ends of an arc should be trimmed.
August 2, 2023 at 4:58 am
August 2, 2023 at 5:04 am
Praneeth Munaga
Ansys EmployeeIt is possible to round the edges using the "fillet" option in the draw menu. For detailed information on this, please refer to "Rounding the Edge of Objects (Fillet Command)" in the HFFS help document.
August 2, 2023 at 10:13 am
August 2, 2023 at 11:50 am
Praneeth Munaga
Ansys EmployeeIt is not possible to remove the said places using healing option. As I suggested you earlier, you can remove these unwanted portions by subtracting them with some maksing objects. Please create dummy objects that will overlap with only thes unwanted portions and do boolean subtraction.
- The topic ‘Replicating a section of cylinder with elements into full cylinder’ is closed to new replies.
5979
1307
