August 23, 2024 at 2:38 pm
ferhat.ozmen
SubscriberWhile working on the ANSYS Workbench interface, when I try to change the name of the analysis module window by right-clicking on my already saved .wpj.li file and using the "Rename" command, I encounter a Microsoft JScript runtime error. The Workbench file automatically closes, and I can no longer open these files.
As a workaround, I am forced to rename the ANSYS version in the %appdata% folder to 'v242_old'. "Rename" is a frequently used command, and I would like to know what steps need to be taken to prevent this issue from occurring in the first place. Thank you for your consideration. -
August 30, 2024 at 10:51 am
Rajeshwari Jadhav
Forum ModeratorHi Ferhat,
Try to rename whole Ansys folder (%appdata%). How frequent is this issue?
- Contact stiffness too big
- Test post on Forum – LLM response – SC
- 13-Node Pyramid Element Shape Function
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
1494
1386
1209
