November 12, 2024 at 6:38 am
November 15, 2024 at 7:10 am
Jie Yan
Ansys Employee看结果图这个应该是本征模,本征模仿真可以看结构本身的谐振模式以及对应的谐振频率,不能直接来看材料衰减,可以大概通过Q值大概看出不同谐振模式下的整个结构系统的衰减特性,也就是谐振时保存能量的能力,该值越小表明系统衰减越快。
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
1363
1194
