TAGGED: ansys-mechanical, ansys-student, ansys-workbench, mesh, surface-coating
March 14, 2022 at 10:01 am
RohanJuneja
SubscriberIs it possible to model multi layer surface coatings in ansys? Since Ansys doesn't give the option of surface coatings in the scoping method while creating a surface coating
March 16, 2022 at 7:30 pmAshish Khemka
You can model multiple layers/ shell elements.
Regards Ashish Khemka
March 29, 2022 at 5:43 amRohanJuneja
SubscriberBut is it possible to stack multiple layers of surface coatings on top of each other?
Because when I try to create multiple coatings, the scoping method only allows to select geometry, there is no option to select a surface coating as a surface on which another coating can be modelled.
could you please shed some light on the issue?
March 29, 2022 at 3:30 pmpeteroznewman
SubscriberAnsys supports Composite modeling. Read this chapter in the ANSYS Help system. First open the Help system, then copy/paste the following text into the URL address.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/ans_str/Hlp_G_STR11_2.html
May 2, 2022 at 10:47 amRohanJuneja
Subscriberis it possible to define the adhesion between two layers that I have created as a composite? The geometry I am creating isn't an actual composite but its a combination of three surface coatings stacked on top of each other. I am trying to create that geometry as a composite. In this case, what should I do to define the adhesion between the each layer?
May 3, 2022 at 9:17 ampeteroznewman
SubscriberI don't know. Someone who knows a lot about composites might answer.
Viewing 5 reply threads- The topic ‘Regarding surface coatings’ is closed to new replies.
6625
1311
