January 11, 2024 at 4:27 am
ANUPAMA
SubscriberHai, I am writing to seek your assitance regarding ansys analysis. Iam trying to do a finite element analysis in ansys mechanical. i have modelled a ship with longitudinal girders, trransverse frames and bulkheads. I will attach my model below.Â
I have to find out the pressures and motions acting on the ship due to waves. I have found that using ansys aqwa. And mapped the results to ansys mechanical. I have used the hydrodyanmic pressure tool from ansys mechanical to apply these results to ansys mechanical. But applying i have got errors such as "an unkown error occured view solver output in solution information. I have applyed the boundary condtions through remote points. I have given hydrodynamic pressure and standard earth gravity. But no luck!!! If i suppress the hydrodynamic pressure tool then there were no errors.Â
I don't know the reason. Kindly help me to fix this probelm. Iam working on my final project.Â
Thanks in advance.
January 11, 2024 at 7:21 am
Akshay Maniyar
Ansys EmployeeHi Anupama,
It looks like you have a duplicate post for the same query, so I will close this one and we can continue with the other post.
Regarding finite element analysis (ansys.com)
Thanks,
Akshay Maniyar
- The topic ‘Regarding finite element analysis’ is closed to new replies.
6680
1313
