June 6, 2023 at 4:37 am
teddie smith
SubscriberAs far as I know, there is a parameter called 'reflection index' that relates to the reflection and transmission of a material surface. I wonder what this value is set to in FDTD.
June 8, 2023 at 5:30 pm
Guilin Sun
Ansys EmployeeÂ
Do you mean how to set the material property the refractive index in FDTD?
If so, there are mainly two methods to assign the refractive index:
1: if it is a fixed value, or diagonal anisotropic, you can directly assign it:
2: use the material database. For example, Silicon:
Please refer to
https://optics.ansys.com/hc/en-us/articles/360044941894-Material-Properties-Introduction
https://optics.ansys.com/hc/en-us/articles/360034901473-Rectangle-Simulation-Object
If you want to calculate the refractive index from reflectance and transmitance you can by whatever the software/script you have at hand. Lumerical software only needs the refractive index or permittivity for simulation. You can import it  https://optics.ansys.com/hc/en-us/articles/360034915093-Creating-new-sampled-data-materials-in-FDTD
- The topic ‘Reflection index’ is closed to new replies.
6790
1332
1152
