TAGGED: ansys-mechanical-apdl, ansys-thermal, transient
July 15, 2024 at 5:05 pm
Leon15
Subscriber -
July 16, 2024 at 2:34 pm
Ashish Khemka
Forum ModeratorHello,
Please see if the following forum thread helps you: Reducing Result File Size in Transient-Thermal-Electric Simulation (ansys.com)
Ashish Khemka
July 16, 2024 at 8:44 pm
Leon15
SubscriberThanks for the quick reply, the forum did provide some useful insight. However, I am failling to understand how to applied the OUTRES command to all the loadsteps, let's say I use the following command in the PREP7/:
OUTRES,ERASEOUTRES,all,NONEOUTRES,STATÂI expect it to apply to all the loadsteps. However, according to my tests it applies to the first loadstep only. Am I missing something or is there a way to apply the OUTRES to all the loadsteps with a single command, because my simulation contains a high number of loadsteps.ÂÂCheers,ÂLeon -
July 18, 2024 at 8:35 am
mashetty
SubscriberI know that using outres, the size of the output file can be reduced, but there is also an alternative method using the output controls in the Ansys analysis settings. In the Ansys analysis settings, you can find the output controls, and here you can find an option to store results using different options available.ÂAnalysis setting < Outputcontrosl < Store results at < Choose the optionÂÂ Please check all the options. I generally use the specific recurrence rate of 5 , which stores the results for every 5 substeps(As shown in the image ). This is a very simple way of doing it, but just give it a try.Â
Bests,
Vamshi
July 23, 2024 at 1:54 pm
Leon15
SubscriberHello,
Thanks for the suggestion, I am using APDL, but I'll try to find the equivalent command and give it a go.
Viewing 4 reply threads
- The topic ‘’ is closed to new replies.
1306
