Electronics
Electronics
Reduce analyzed time Maxwell simulation
    • andrein13
      Hello.
      How can I reduce the simulation time? For example, for the attached picture settings, the analysis time takes up to 1 hour to get a graph.
      Thank you!
    • icellb1
      Hi, ,nWe are not allowed to click on non-displaying images, could you please attach your screenshot again using upload image rather than upload file? Thank you.n
    • andrein13
      Hi,nFor example with this paramaters the analysis time takes up to 1 hour and after that I can see the results.nnn
    • icellb1
      Hi,nSaving fields at each fine step would definitely cause long solving time, if you don't need to plot fields at each step you can choose to save it at a few time steps of interests. This will largely reduce running time. n
    • viswashh
      Hello there! I am also having similar problem when I do ANALYZE in my WPT system coils. My solver doesn't even solve for 4 hrs. What's the problem?n
Viewing 4 reply threads
  • The topic ‘Reduce analyzed time Maxwell simulation’ is closed to new replies.
