July 3, 2024 at 9:17 pm
Zheng Yang
SubscriberHi all,
Redhawk version: 2023 R2.1 RHEL7
I using Redhawk to do the static IR drop analysis. I include a package subcircuit and want to calculate the IR drop from ideal voltage sources defined in the package subcircuit to any instances or wires. When I lookde at the pad voltage map, I found some mistmatch between the value in the text and colorbar value. I don't know how value in the text is calculated and this value is not the voltage drop value. Like in the figure , the value of right column is larger than the middle red square, but the color is not red. Â
July 22, 2024 at 10:39 am
Praneeth
Ansys EmployeeHi Zheng,
Thank you for reaching out to the Ansys learning forum. Your patience is much appriciated.
Unfortunately, this question is beyond the scope of ANSYS employees to answer on a public forum. So, hopefully other student community users can chime in.
Best regards,
Praneeth.
- The topic ‘Redhawk Pad Voltage Problem’ is closed to new replies.
4763
1565
1386
1242
